b16 head torque sequence and specs?
ARP studs vary depending on the stud thickness follow the torque sequence in the helms and follow the torque rating of the manufactuer that made your bolt. ARP provides that on the given box.
stock tq sequence but for safety add a couple steps. if not using ARP assembly lube you will have to add tq, its like an additional 15lbs using 10w30
