can use h23 stuff on a h22 like ALTERNATOR starter Distributor crank rod ?
Alternators are the same, the difference is the alternator pulley. The H22 is a little wider than the H23.
Power steering pump is the same.
AC compressor is the same.
Starter is the same.
Distributor is the same.
The blocks are the same
The oil pan is the same.
The oil pickup tube is the same.
Crank, rods, and crank pulley are the ONLY difference between the two bottomends.
thanks man check out my site http://www.prelude92.piczo.com
alternator, difference, distributor, distributors, fit, h22, h22a, h23, pickup, prelude, pulley, pully, same, starter, starters, tube
