Does anyone know how to reset the SRS light on a 01 civic?
Old Dec 14, 2004 | 11:47 PM
slowcivic888's Avatar
Default Does anyone know how to reset the SRS light on a 01 civic?
My SRS Light is on, does anyone know if disconnecting the battery cable resets it? If there is other ways please let me know. Thanks everyone
Old Dec 15, 2004 | 12:42 AM
_Cyclone_'s Avatar
Default Re: Does anyone know how to reset the SRS light on a 01 civic? (slowcivic888)
If your SRS light is on, then something is wrong with your airbag system. Diagnose and fix the problem, and the light will go away. To find out what is wrong, you may need a scan tool, unless there is a way to get the code out that I don't know of.
Old Dec 15, 2004 | 06:32 AM
TouringAccord's Avatar
H-T Order of Merit
run a search on SRS. You will find the instructions on how to do it.
CycloneBlue_1.6EL is right though. That light doesn't just come on for no reason. Either there is a problem or you disconnected something that caused an error in the SRS system.
I think I read that you can jumper the mes service connecter, similar to how you check CEL's just with a different plug, and then the srs light will flash the code just like a CEL would. I've never done this though so I don't know if this is true.
Reaccion
Honda Civic (2006 - 2015)
24
Oct 20, 2017 11:26 AM
_Cyclone_
Honda Civic (2001 - 2005)
Jun 2, 2009 08:25 PM
jdmrida
Nov 21, 2008 08:58 AM
97RSTEG
Jun 24, 2006 12:10 PM
vladd
15
Jul 17, 2003 12:52 PM
