JG could you help this guy out....
Old Jan 3, 2002 | 07:53 PM
laughinxxx's Avatar
New User
Default JG could you help this guy out....
http://www.preludeonline.com/showthr...threadid=43588
The guy asked if you had to resleeve the block when running forged pistons. I know you're supposed to, but I don't have a clue why.
Old Jan 4, 2002 | 08:44 AM
boomslang's Avatar
Default Re: JG could you help this guy out.... (laughin2.2)
As long as you don't overbore too much, you will be fine with forged pistons and stock sleeves.
Jeff at Importbuilders says they do it often.
[Modified by Inlinefour, 11:46 AM 1/4/2002]
Old Jan 4, 2002 | 08:49 AM
laughinxxx's Avatar
New User
Default Re: JG could you help this guy out.... (Inlinefour)
Are you talking about 4Gs as well?
Old Jan 4, 2002 | 09:38 AM
JG Luder's Avatar
I've always herad that because of the material the sleeve is made of, you don't want to bore it. *hone* it, yes.
As for the stock material and the forged pistons, what gsr*lude said was what I've heard also. I've never actually seen anyone run a forged piston on a stock sleeve, and I've never done it, so I'd be reluctant to tell you exactly what would go wrong. However, the stock sleeve isn't as hard as an aftermarket and a forged piston is much more harsh than a stock. I leave the math to you.
Old Jan 4, 2002 | 12:24 PM
boomslang's Avatar
Default Re: JG could you help this guy out.... (JG Luder)
It's all about the RINGS.
Old Jan 4, 2002 | 12:30 PM
JG Luder's Avatar
Rings and preventing harsh contact of the pistons and walls.
Tell you what, toss in a set on a non sleeved motor and we'll see what happens. I'm not going to do it, but if you think it's safe, try it. If it runs and races for a year without trouble, then you've proven your point and I'll say that what I heard before was wrong.
Old Jan 4, 2002 | 12:39 PM
boomslang's Avatar
JG, take a look at the bottom of this thread. I have no firsthand knowledge of stock sleeves with aftermarket pistons, but I trust what Jeff says.
https://honda-tech.com/zerothread?id=99774
Old Jan 4, 2002 | 12:45 PM
JG Luder's Avatar
not that I doubt Jeff, I just will never do it.
Old Jan 4, 2002 | 02:32 PM
DirtyLude's Avatar
Rather than bloat another thread on this. JE specificly states that you cannot run their pistons on stock sleeves. It doesn't look like any of us have any better answers, so if anyones concerned about it, a call to JE would probably answer some questions.
Old Jan 4, 2002 | 07:34 PM
Greyout's Avatar
Default Re: JG could you help this guy out.... (DirtyLude)
JE told me that if you went with a custom piston, you could use the stock sleave. that means custom compression ratio, and around an extra $100
NonovUrbizniz
Oct 28, 2009 01:26 PM
OMG B16
Apr 22, 2006 05:22 PM
Black R
Mar 17, 2005 07:22 PM
Ri5e
Apr 3, 2003 08:52 PM
MisterB
Jan 15, 2002 11:26 AM
