What WHP to expect out of my build?.... in progress
hey guys im just curious bout wat kind of numbers my planned set up will produce.
Car the motor is going in: white 1993 honda civic si hatch
Motor: JDM B16A1
What im doin to the motor:
Head: new valvesprings, retainers, 3 way angle valve job, stage 2 or 3 cam shafts, and get the head shaved for higher compression.
Block: stroker kit (going from 1.6L to 2.0L), bore the block to 84mm.
Other: Upgrade fuel system-fuel rail, injectors, fuel pressure reg, MSD ignition, new cam gears, underdrive pulleys, individual throttle bodies, headers, exhaust, and all the other little things......gaskets and stuff.
So what you guys think? how much power will this setup produce to the wheels? throw out some numbers and when the motor is complete, in the car, tuned and dynoed i'll let you guys know who was the closest. thanx for takin the time to read and respond.
730_Si
Motor: JDM B16A1
730_Si
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nvmyb20hatch »</TD></TR><TR><TD CLASS="quote">depending on which pistons you choose id say between 170 and 220</TD></TR></TABLE>
I chose 220 for mine :/
that is a large range
yc_dc4mar
24
Jan 15, 2007 11:15 PM
