what open ended lig nuts for extended ARP wheel studs
Old Dec 14, 2004 | 07:16 PM
mrbsponge's Avatar
Default what open ended lig nuts for extended ARP wheel studs
just wondering what lug nuts yall are using on ARP extended studs??
i already had some of those light weight type deals but they kept stripping out.
i run slicks on my car so i want something strong and not the light weight kind
so what are you using,
places to buy, brand and pics would be nice
Old Dec 15, 2004 | 10:07 AM
mrbsponge's Avatar
TTT, anyone
Old Dec 15, 2004 | 01:17 PM
mrbsponge's Avatar
again
Old Dec 15, 2004 | 01:19 PM
NJcoupe's Avatar
oem open ended lugs
Old Dec 15, 2004 | 04:13 PM
Newman's Avatar
New User
Default Re: what open ended lig nuts for extended ARP wheel studs (mrbsponge)
Anything that is 12mm x 1.5 open ended (for the Civics & Integras)
Old Jan 27, 2007 | 05:00 PM
Boricuanology's Avatar
Default Re: what open ended lig nuts for extended ARP wheel studs (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">Anything that is 12mm x 1.5 open ended (for the Civics & Integras)</TD></TR></TABLE>
I Don't think thats the case, I have whole set of open ended 12mmx1.5 and I couldn't use them. I can install them by hand but you see, the adapter that you use to install/remove them gets attatch to the open end of the lug nut. So in my case when Im installing them the wheel stud will come all the way thru the opening end of the lug nut , and once this happend I can't use the factory adapter. So I guess they have to be open ended but long enough to reach all the way. But then again I think the ones I have are made to be use with factory wheel studs.
Modified by Boricuanology at 2:38 AM 1/28/2007
Old Jan 27, 2007 | 05:33 PM
Luserkid's Avatar
Default Re: what open ended lig nuts for extended ARP wheel studs (Boricuanology)
I cut the top off my regular honda lugs and they turn open end, works great.
Old Jan 27, 2007 | 06:52 PM
sicones's Avatar
Default Re: what open ended lig nuts for extended ARP wheel studs (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I cut the top off my regular honda lugs and they turn open end, works great. </TD></TR></TABLE>
*not with aftermarket wheels
Old Jan 27, 2007 | 08:10 PM
Luserkid's Avatar
Default Re: what open ended lig nuts for extended ARP wheel studs (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">*not with aftermarket wheels</TD></TR></TABLE>
Havent had a problem with my lenso's minus a little paint chipping *knock on wood*
93grayeg
May 12, 2011 09:37 AM
Saosinx
Apr 4, 2006 04:43 AM
Jonathan_ED3
Apr 17, 2005 12:56 PM
Vp Special K
Nov 22, 2004 05:39 PM
Jared
Aug 21, 2002 08:02 AM
