LS VTEC BOTTOM END,CTR,CUSTOM RODS,ECT Great deal!!!!!!!!!!!!!!!!!!!!!!!!
Just sent into machine shop for rebuild so I can sell it. Its and b18 bottom end with professionally machined rods to accept the ctr pistons. This setup is about a 12.5-1 CR. Remember cast pistons are lighter then forged making them better for all motor setups!!!!The block will have new rings, new bearings (rod and main). Also installed is a block guard. Oil pump is almost new along with the water pump. This motor with a stock b16 head made almost 170 HP to the wheels with bad rings (hence why it is being redone) The crank is in mint condition and DID NOT spin a bearing. I dyno’d the car myself on a mustang dyno at my college. Note that was with a LS ecu and a vafc. With sum real tuning and sum other lil bolt on’s u could make a lot more power. I’m taking offers of 750 dollars and maybe sum trades. This is located in NY I will ship at buyers expense and I am pay pal certified. Plus the 3 %
Note-Block is in machining process so I should have it back in a few weeks and I will take a deposit to hold if u need sum time to gather the money. thanx
DavidT or VajT
Northern California (Sales)
69
Apr 21, 2006 08:53 PM
bump
