How To: Install SRR Ignition Switch
Old Dec 14, 2004 | 06:18 PM
Top-Fuel's Avatar
Default How To: Install SRR Ignition Switch
Could someone help me out here, I did some searching on google and other forums but can't find any good info on exactly how to install the SRR Ignition switch.
Old Dec 14, 2004 | 06:20 PM
Archidictus's Avatar
Unceasing Measure
Default Re: How To: Install SRR Ignition Switch (Top-Fuel)
Did it come with instructions?
Old Dec 14, 2004 | 06:28 PM
Top-Fuel's Avatar
Default Re: How To: Install SRR Ignition Switch (Archidictus)
nope, I usually check the item first before. Not sure why it didnt' come with one, hopefully someone out there has installed a SRR ignition/kill switch.
Old Dec 14, 2004 | 07:54 PM
Top-Fuel's Avatar
some advice anyone? Tried searching again but nothing.
Old Dec 14, 2004 | 08:08 PM
jlacoy82's Avatar
71.192.16.183
Crazy, but have you tried contacting SRR? Maybe they would know?
Old Dec 14, 2004 | 08:53 PM
slammed_93_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Top-Fuel &raquo;</TD></TR><TR><TD CLASS="quote">nope, I usually check the item first before. Not sure why it didnt' come with one, hopefully someone out there has installed a SRR ignition/kill switch.</TD></TR></TABLE>
i purchased an SRR product befor and it didn't come with instruction's either.
I guess they have the mentality that if you buy a product you should know how to install it.
if you search around in the racing forums many cars have to have products like these and im sure they have instructions. i think it just involves a ground and running wire/wires to the main relay
Old Dec 14, 2004 | 09:05 PM
Top-Fuel's Avatar
Default Re: How To: Install SRR Ignition Switch (slammed_93_hatch)
I'm just worried about the wiring because I have no clue which wire goes on what part of the switch. From the back of the switch it looks like there are 4 wires that connect to it but the problem lies to what wire connects to which part of the switch.
Guess i'll have to do a trial and error.... (worse comes to worse)
Old Dec 14, 2004 | 09:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Top-Fuel &raquo;</TD></TR><TR><TD CLASS="quote">I'm just worried about the wiring because I have no clue which wire goes on what part of the switch. From the back of the switch it looks like there are 4 wires that connect to it but the problem lies to what wire connects to which part of the switch.
Guess i'll have to do a trial and error.... (worse comes to worse)</TD></TR></TABLE>
im teh suck at electrical ****, but get a 12volt battery and a tester, hook it up and do testest with that to see which is which
Old Dec 14, 2004 | 09:58 PM
Top-Fuel's Avatar
Good idea thanks alot!
Old Dec 15, 2004 | 03:28 AM
EE_Chris's Avatar
You're going to use 'trial and error' on your cars electrical system??
Is it really that hard to call SRR and go from there?
Do you at least have the Helms schematic for the circuit you're about mess with?
Old Dec 15, 2004 | 03:36 AM
Deemeetree's Avatar
Electrician
DO NOT do trial and error on electrical systems. That is the WORSE thing you can do. Call or contact SRR, the SMARTEST thing you can do. From the looks of it, you REALLY DO NOT want to use trial and error because it does sound to me that you WILL screw something up...royally.
Old Dec 15, 2004 | 06:15 AM
BigZ88's Avatar
Default Re: (Dimi)
i'd suggest searching for an install of an s2k push button start. Also, try Ignited performance for a wiring diagram of their push button starts. I'm sure they have some sort of instructions with their products.
Old Dec 15, 2004 | 01:32 PM
Top-Fuel's Avatar
Default Re: (BigZ88)
Yeah i got the helms booklet yesterday, was looking at the wiring etc. Must admit, looks pretty complicated but dont' think it would be once i see the wires etc. myself.
and for the s2k push button i was thinking of that as well. Thanks for input though guys!
Old Dec 15, 2004 | 02:01 PM
B2FiNiTY's Avatar
Default Re: (Top-Fuel)
Does SRR have a us distributer you can talk to? Otherwise good luck trying to talk to them in Taiwan.
ser13
Audio / Security / Video
Jan 17, 2007 04:44 PM
Top-Fuel
Mar 10, 2005 01:21 AM
RuthlessEF-9
Feb 15, 2005 02:42 PM
StreetRacnGsR
May 18, 2003 12:21 PM
