Distributor Problems.
Old Jan 3, 2002 | 07:00 PM
94cxHybrid's Avatar
New User
Default Distributor Problems.
I did a search and found no direct answer. I have an obd 1 distributor or a Gsr.
1) On the two wire plug the blue wire, i have no power to this wire when the key is on. All fuses are good. Should there be power?
2) If the bearings are gone in the Dist. Will the rotor still turn when i crank the car?
Thanks in advance.
jj17
Jan 11, 2014 11:01 AM
accordselux
Feb 20, 2006 12:25 PM
