What airintake manifold do I need for my swap?
Old Dec 14, 2004 | 04:07 PM
dropdaccord's Avatar
Default What airintake manifold do I need for my swap?
Im currently putting a D16Y7 motor and tranny out of a 98 civic into my 93 delsol. The delsol had a D15B7 in it. I was told from racingworks.com that all i need to do is
-change the driver engine mount of the 98 civic to the del sol style (you will have to take the timing cover off to swap brackets)
use
98 Civic D16Y7 Block and Head
del Sol engine harness
del sol intake manifold
del sol distributor
del sol computer (leave plugged in the chassis)
crank sensor on the 98 Civic engine will not be used, this will be read in the del sol distributor which you are reusing on the new engine
Now that all made sense to me besides using the stock delsol intake manifold because its off of a D15 going onto a D16. I called advanced auto to have them check out the part # for both the D16 and the D15 intake manifold gasket and they were completly diffrent. So what intake manifold do I use on the D16, jus any D16 series motor between 92-95? Thx
xx7xx
22
Nov 25, 2008 04:49 PM
A1
Northern California (Sales)
Dec 23, 2006 01:42 PM
honda06si
Jun 16, 2005 09:52 PM
