Engine light, ecu wireing help
my check engine light is on and the code is for checking for the 2ndary O2 sensor. its code 21 I think. My car is a b16a in a crx. My shop tells me that it is wired up right, the wire is just loose (halfass install). What wire am i looking for to get it all tight? pictures or the ecu pinout would be nice. Do I need to give you all any other information? Im not sure what my ecu is, it would be the one that came with my b16a swap. JDM ecu I think!
did you convert to obd1 or is it obd 0 still? what ecu? look on the side of your ecu and it should have a bar code , read the bar code and it should be someting like 37820-pm8-a020(my old hf ecu).So from that bar code we know that my ecu is a Pm8.Good luck.
if you really have the jdm ecu check this out http://www.geocities.com/b16ap....html. Thats all i can think of.
lakahang
Dec 19, 2009 03:23 PM
z6CRXSi
Jun 7, 2005 12:41 PM
