code 2??? no check engine light but cel flashes constant
Old Dec 14, 2004 | 09:04 AM
thatbluecrx's Avatar
Default code 2??? no check engine light but cel flashes constant
preobd b16a in a crx.. there are no check engine lights but the ecu is constantly blinking code 2, i cant find code 2 anywhere, anyone have this problem?
Old Dec 14, 2004 | 10:55 PM
Default Re: code 2??? no check engine light but cel flashes constant (thatbluecrx)
my 1st bump
Old Dec 23, 2004 | 05:34 PM
bump
Old Dec 27, 2004 | 04:00 PM
bump
Old Dec 27, 2004 | 09:29 PM
eda6's Avatar
code 2 is second o2 sensor
The car threw a code 2 at one time. To make the ecu stop blinking pull the hazard fuse or disconnect your battery for about 30 seconds. Code 2 will return if you have a problem
Old Dec 28, 2004 | 01:34 AM
Default Re: code 2??? no check engine light but cel flashes constant (eda6)
ive done that, it does return, i have only 1 o2 tho...
1st gen b16a pre-obd
Old May 17, 2006 | 01:40 PM
patriot's Avatar
Same issue here. OBD0 B16A in a 90 Civic. I tried out a new chip today and it happened. The CEL is flashing twice, not the LED on the ECU. I also had very low fuel, though I doubt that was it. I've been a Honda guy for years and this is the first time I've come across this.
doom26464
Aug 26, 2008 07:45 PM
HSPxNick
Oct 16, 2006 11:27 PM
The Punisher
Sep 1, 2001 03:11 PM
Yellow Dragon
Aug 5, 2001 01:04 PM
