spun rod bearing...
Old Dec 14, 2004 | 04:28 AM
91teg's Avatar
Default spun rod bearing...
i spun a rod bearing in a 93 coupe EX. can i just put new bearings in the engine or do i need to go oversized? Thanks
Old Dec 14, 2004 | 04:42 AM
Archidictus's Avatar
Unceasing Measure
Default Re: spun rod bearing... (91teg)
If the crank is okay and the tolerances fall within spec when you plastigauge it you can just use OEM ones. If not, you'll have to go oversized .
Jdmkids Manny
Engine Machining & Assembly
Feb 1, 2016 12:37 PM
hardcore97
Apr 23, 2015 07:55 PM
igorka_91
13
Jul 5, 2009 12:29 PM
dj-t
Jul 2, 2009 08:48 AM
92hatchattack
Jun 7, 2005 09:21 AM
