Rocket M22 in a stock CR GSR
Old Dec 13, 2004 | 07:23 PM
1994GSR's Avatar
Default Rocket M22 in a stock CR GSR
I am thinking about running the rocket M22 cams and valvetrain in my stock compression ratio GSR. Will they work or are they ment for a higher compression ratio engine?
Old Dec 21, 2004 | 02:19 PM
Rocket's Avatar
Default Re: Rocket M22 in a stock CR GSR (1994GSR)
They will work but you'll need to optimize the header and intake manifold.
Old Dec 21, 2004 | 06:22 PM
spooncivic1's Avatar
what kind of power would these cams make over BC3+'s or BC4's on around 11.8:1 cr, with a GOOD header and intake manifold
Old Dec 21, 2004 | 09:01 PM
Rocket's Avatar
Default Re: (spooncivic1)
Sorry don't know that answer. Maybe soon though.
Old Dec 22, 2004 | 09:27 AM
1994GSR's Avatar
Default Re: Rocket M22 in a stock CR GSR (Rocket)
Rocket right now I am running :
A DC4-1 header
Honbdata
comptech icebox intake
60mm mandrel bent exhaust with 2.5 magnaflow rear
aem cam gears
My next modifications will be
_A skunk2 intake manifold
_Rocket M22 Cams, springs, retainers
I like to autocross my car on occasion, will I loose alot of mid range by going to the m22 set up? I also like to go run open road track days, I think the m22's will be a great on the track.
Old Dec 22, 2004 | 09:54 AM
VtecKiDD's Avatar
m22s
Old Dec 22, 2004 | 09:59 AM
Rocket's Avatar
Default Re: Rocket M22 in a stock CR GSR (VtecKiDD)
very coo. They make power longer than other cams I've seen.
lilo_goki
20
May 20, 2009 07:37 AM
prjctwhteg
May 30, 2008 08:57 PM
prjctwhteg
May 29, 2008 08:59 PM
nate_2k5
Nov 6, 2007 12:31 PM
EK9 BEEZLER
Mar 24, 2005 08:05 PM
