What other bolt ons should i do before i head to the dyno??
Old Dec 13, 2004 | 07:03 PM
92eg6's Avatar
Default What other bolt ons should i do before i head to the dyno??
i have a b16a2 w/intake. jdm 4-1 headers, apexi ws exhaust, chiped p28 6700-9000 vtec and this weekend am installing an aebs manifold, 65mm tb, and a vafc, im just wondering what other bolt ons should i add before i head to the dyno, im not looking to do anything internal, would cam gears help at all w/stock cams? im not looking for amazing numbers from my b16 but with tunning im hoping to see 145-150?
Old Dec 14, 2004 | 08:19 AM
tgreaves's Avatar
Default Re: What other bolt ons should i do before i head to the dyno?? (92eg6)
Why do you need a vafc if your running a chipped p28.. Just get uberdata and burn your own program..
Old Dec 14, 2004 | 09:44 AM
92eg6's Avatar
Default Re: What other bolt ons should i do before i head to the dyno?? (tgreaves)
yea i know just that while i was getting my ecu chipped i saw a vafc for $100 so i jumped on it, im looking into the uberdata i thought a data logger was needed but i hear its not, and also wouldnt tunning a vafc be cheaper then w/uberdata i know its free but the actual dyno time and tunning time put into it.
Old Dec 14, 2004 | 09:52 AM
tgreaves's Avatar
Yes but you can get a more accurate fuel and ignition timing when using a tuning system like uberdata..
Old Dec 14, 2004 | 10:11 AM
92eg6's Avatar
i guess ill jus go w/uberdata, jus found out today that all i need is the atmel 29c256 eprom chip guess ima sell the vafc to my cuz, but wat other simple boltons might make a difference, would camgears on stock cam do nething?
Old Dec 14, 2004 | 10:16 AM
tgreaves's Avatar
Well you can move your power curve a little with adjustable cam gears on a dyno.. Mainly if you modify your car if different then what honda designed it for and adjustable cam gears will get you a little bit more power when adjusted properly..
In addition to the Atmel 29c256 chips your also going to need a burner if your doing any tuning yourself.. Check into a willem burner..
H22Honda98
Aug 4, 2007 10:39 PM
Euro98ITR
Mar 26, 2005 12:45 PM
Quiks66
Aug 4, 2004 10:08 PM
Quiks66
Aug 4, 2004 07:12 PM
pbizzlegsr
Feb 25, 2004 07:16 AM
