Evap Valve/Canister...easy fix?
Old Dec 13, 2004 | 07:02 PM
Josh10e's Avatar
Default Evap Valve/Canister...easy fix?
Part 2 to my P1457 code...everything is seeming like either an evap valve or the canister...
Pardon me, but newbie here...easy backyard fix or bring to dealer?
If backyard fix...should I buy the valve, or canister...both...or what do you recommend?
Thanks,
Josh from MN
'99 Accord V6
2 Door
56,000 Miles
Minnesota Car
Old Dec 14, 2004 | 11:51 AM
Turbowa's Avatar
Default Re: Evap Valve/Canister...easy fix? (Josh10e)
Its the valve that goes bad. The only reason to replace the canister is if the the screws for the valve rust and seize into the canister.
Old Dec 14, 2004 | 04:54 PM
hondadude's Avatar
Here's a link to a zip file that will put you in the right ballpark.
http://members.troublecodes.ne...7.zip
Best of luck I hope this helps you.
CAM0FLAG3
Apr 1, 2009 06:54 PM
vinuneuro
Apr 24, 2007 06:05 AM
Blown90hatcH
Sep 26, 2001 06:35 PM
