Positive and Negative Offset???
Old Jan 3, 2002 | 02:01 PM
JohnnyM's Avatar
Default Positive and Negative Offset???
How exactly does this work. I thought if you have a positive offset and then changed it to an even bigger positive offset the rims would sit farther out on the car causing more chance of rubbing on the wheel well.. Am I right or is it the other way around....
Old Jan 3, 2002 | 06:35 PM
getfast's Avatar
Default Re: Positive and Negative Offset??? (JohnnyM)
http://www.tirerack.com/wheels/tech/offset.htm
Hope that helps,
Jon
A.S.I.M.O
Oct 4, 2006 02:52 PM
cappelhans
10
Jan 23, 2006 06:32 AM
gregv21
Jan 28, 2004 06:18 AM
9d9GSR
May 21, 2002 12:53 PM
Jaisun
May 5, 2002 01:01 PM
