Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Any benefits in using urethane endlinks for the ITR Swaybars on my '92 VX?
Old Jan 3, 2002 | 01:23 PM
ESCALVANTE's Avatar
Default Any benefits in using urethane endlinks for the ITR Swaybars on my '92 VX?
I have a '92 VX with JDM ITR springs, shocks, and LCAs installed at all four corners and I also have the USDM ITR Front (25mm) and Rear (22 mm) Swaybars sitting in my garage waiting to be installed.
Before I install the swaybars (using the Beaks and Prothane mounting kits for the rear bar), I wanted to know whether or not there are any benefits in using urethane endlinks?
If there are, does anyone know where I could get some?
TIA
Old Jan 3, 2002 | 06:59 PM
Civic242's Avatar
Default Re: Any benefits in using urethane endlinks for the ITR Swaybars on my '92 VX? (ESCALVANTE)
Well I'd say you need to be looking to beef up your sub frame before that beffy bar rips it apart. A rear 22mm bar is very thick and could do some major damage if your don't use larger reinforcement plates.
Old Jan 3, 2002 | 07:10 PM
Crack Monkey's Avatar
It'll make the bar a bitt stiffer, as the stock rubber stacks are more flexible than the upgraded polyurethane. Probably not a big difference though.
Old Jan 3, 2002 | 11:44 PM
ESCALVANTE's Avatar
Default Re: Any benefits in using urethane endlinks for the ITR Swaybars on my '92 VX? (Civic242)
Civic242: About the subframe being ripped; I am aware of this problem and that is why I will use both the Beaks and the Prothane mounting hardware for the rear bar.
Anyone know where I can get these endlinks?
ESCALVANTE
Jun 7, 2002 11:48 AM
ESCALVANTE
Jan 4, 2002 12:38 PM
ESCALVANTE
Dec 27, 2001 09:38 AM
