Type R injectors for H22A swap???
96 lx accord with 93 h22a JDM...is it true that the resistor frequencys are different for the accord than the h22 and the injectors need to be changed to type r...I hope i worded that right??? thanks!
but isnt there a difference in the resitor boxes??? If so wouldnt it be easier and cheaper to just get the box??? Thanks! Im just learning about the whole injector resistor deal...
I was thinking since it is a resistor box on a obdII car and he's swapping an obdI engine into it, it might be different and he needs to get an obdI resistor box. I guess not though? This has been bugging us, thanks for the help.
while we are on the topic of injectors, i think i have a problem with my injectors after my swap. i converted my car to stick, and while i was at it i put in a new engine out of a 2001 accord. now the car is getting fuel to the rail, so i think its the injectors.
i dont know what the problem is though. is it the fact that i have a different year motor in my car, or is it that i converted to stick that is making my injectors not work??
could all four injectors really go bad all at once? i considered that, but for a 2001 engine, i couldnt see that happening. the only code i'm getting is something about the intake idle thing, but would that stop it from running?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klutch44 »</TD></TR><TR><TD CLASS="quote">while we are on the topic of injectors, i think i have a problem with my injectors after my swap. i converted my car to stick, and while i was at it i put in a new engine out of a 2001 accord. now the car is getting fuel to the rail, so i think its the injectors.
i dont know what the problem is though. is it the fact that i have a different year motor in my car, or is it that i converted to stick that is making my injectors not work??</TD></TR></TABLE>
have you cehcked t see if htey are sprayig or not? or if you are getting spark?
I did a h22a4 swap in my 97 accord. We originally thought the probs we were having was b/c of the injectors. Turned out the ecu we were using had diff. fuel mapping and ignition timing that was making it run like sh*t.
and 345cc for h22
