d15b vtec clutch setup, what are you guys.....
Old Dec 13, 2004 | 11:04 AM
stealth civic's Avatar
Default d15b vtec clutch setup, what are you guys.....
Ordered my d15b vtec from usedforeignengines.com for 630 shipped. Now, Im not sure how the clutch that is attached to my old zc will hold, since I never really got to drive it. On ebay there are clutches for $88.00, exedy organic OEM. Should I go a head and get one for a d16z6 or get one for my 91 Si? I figure the z6 one will hold better, but I want to make sure the fitment is correct as well. Also, you d15b guys, what clutch setup are YOU running. Thanks
Old Dec 13, 2004 | 11:19 AM
Judd's Avatar
Default Re: d15b vtec clutch setup, what are you guys..... (stealth civic)
your in a whole lot of trouble dawg
Old Dec 13, 2004 | 11:45 AM
Default Re: d15b vtec clutch setup, what are you guys..... (Judd)
why do you say that?
Old Dec 13, 2004 | 11:56 AM
Simon Tibbett's Avatar
ya why?
Old Dec 13, 2004 | 12:25 PM
DJ_SaNdOz's Avatar
I have a D15BVTEC in my EG & I am using a 92-95 EX/Si Exedy OEM replacement clutch. It holds fine for DD, but I think a stage 1 would have better pedal feel. If you just want OEM pressure, etc. It will work fine IMO. I got it for $220ish from http://www.hnaparts.com
Old Dec 13, 2004 | 01:41 PM
blo2k1's Avatar
Default Re: d15b vtec clutch setup, what are you guys..... (DJ_SaNdOz)
i have the lsd tranny that came with the engine and i got a act stage 2 for the 92-95 si/ex seems to work great !
Old Dec 13, 2004 | 08:40 PM
PhatwhipsJDMkits's Avatar
D15b in my 89crx si. Im using the SI tranny with a exedy stage one clutch and a ACT streetlight flywheel. I like it alot. Grips really well not to harsh at all. Just dont go overkill with such a light car if its your daily driver. Clutch i had before my swap was to harsh and it got old fast. Just wasnt needed with the lower power and such a light vehicle.
Brandon1904
11
May 15, 2013 05:53 PM
97accordbuildlx
Sep 26, 2011 01:51 PM
Honda-ls-hatch
Feb 2, 2011 01:50 PM
93eghb
Feb 15, 2008 12:59 PM
Rickcrx
Dec 22, 2003 11:04 AM
