worth running equal length axles?
Old Dec 12, 2004 | 10:58 PM
rice is nice's Avatar
Default worth running equal length axles?
Is it worth it to convert to the ZC equal length axle setup with 90-93 integra axles? Can you even use a quaife LSD with this setup? I heard you had to have a ZC diff, either open or LSD, or entire ZC tranny. I'd rather have the quaife.
Worth it?
Old Dec 12, 2004 | 11:15 PM
Rostr02's Avatar
Default Re: worth running equal length axles? (Killa-X)
if you no longer want torque steer it is worth it
Old Dec 12, 2004 | 11:35 PM
Can you use a quaife LSD with the ZC tranny? Or equal length axle setup though?
I havn't had much torque steer to be honest. My turbo probe GT had a ton of it though.
Old Dec 13, 2004 | 03:17 AM
Rostr02's Avatar
Default Re: worth running equal length axles? (Rostr02)
I had a ton of torque steer and my zc only had cams
You should be ok with a quaife lsd or any for that matter but I would get a half shaft so you dont get torque steer especially if you are going to spend $800 + on a lsd
Old Dec 13, 2004 | 09:26 AM
Yeah, but what half shaft will work with the quaife diff? Because it uses the smaller DX/SI inner cv joints, and the half shafts only come from the ZC, which has a larger bore inner CV.
Can I make a hybrid axle, using the dx inner cv's with the 90-93 integra axle, and the ZC intermeidate shaft?
halvoric
Transmission & Drivetrain
Sep 10, 2009 04:37 PM
johngrady
Jan 28, 2008 01:29 PM
the_asteroid
Aug 30, 2007 02:53 PM
Ef Whore
Dec 1, 2002 08:29 AM
