my all motor build on any suggestions?
Old Dec 12, 2004 | 10:28 PM
jaydmcrx's Avatar
Default my all motor build on any suggestions?
I had fun with my itr, but i want to go with what i have always wanted, and thats bigger, higher compression motor. This is what is in the works as of right now.
motor build up this winter
* means i already have it
00 jdm itr block and head*
85mm ge sleeves
12.5:1 cp pistons
eagle rods
rocket valve train
rocket m24x cams
itr crank*
rc 390cc injectors
walbro fuel pump
an-r compact header*
exedy flywheel*
ported 70mm itr tb*'
aebs intake mani*
Trans (already have)
ys1 b16 with ats 4.9 final drive*
ats 3.0 first gear*
ktp lsd*
gear speed carbon synchros*
polished gear speed type v tranny casing*
This will all be tuned with hondata obviously, and hoping to hold a 11 second time slip in my crx. I already have a great tranny, and suspension components are in the works as well. What do you guys think of the build. 230 whp is my goal whp, but not super important to me either. This is all going in my crx. Is there anything you guys would change as far as the motor is concerned? I have heard great things about rocket cams, and that is what i wanted the most input in actually, but if you see any other flaws please feel free to comment. The build doesnt start til feb. So i have a little more than a month to get things right.
Pics of the motor and car
Modified by jaydmcrx at 3:38 PM 12/13/2004
Modified by jaydmcrx at 2:39 AM 12/19/2004
Old Dec 13, 2004 | 07:46 AM
jaydmcrx's Avatar
Default Re: my all motor build on any suggestions? (jaydmcrx)
Old Dec 13, 2004 | 03:25 PM
kris83's Avatar
looks hot can't wait for a ride.
Old Dec 13, 2004 | 05:00 PM
mtber's Avatar
Cut open that aebs manifold & port it while your at it :-)
Old Dec 13, 2004 | 08:19 PM
DIFFUT'S INC.'s Avatar
Default Re: my all motor build on any suggestions? (mtber)
p&P the head and smooth out the intake manifold also get your bottom end balances
Old Dec 13, 2004 | 08:21 PM
Default Re: my all motor build on any suggestions? (DIFFUT'S INC.)
----->Type R 507 Eddie<---------
Old Dec 13, 2004 | 09:17 PM
estonia is for lovers's Avatar
just plain wow, total sleeper, i love your car haha, i hope everything runs good....sounds good
Old Dec 13, 2004 | 09:47 PM
triple_s1x's Avatar
Default Re: (efniner91)
That is one of the cleanest crx's i've ever seen.
Old Dec 13, 2004 | 11:42 PM
Quitripin's Avatar
knife edge your crank you will help you get closer to your goal
Old Dec 14, 2004 | 08:41 AM
cjohnson_2's Avatar
Default Re: my all motor build on any suggestions? (Quitripin)
Dont forget to get the hondata IM gasket or similar product. It is amazing how much mine helped.
Old Dec 14, 2004 | 09:41 AM
jaydmcrx's Avatar
Default Re: my all motor build on any suggestions? (cjohnson_2)
Actually i have the outlaw engineering gasket kit, works great!!
Old Dec 14, 2004 | 04:50 PM
chameleon's Avatar
klean crx !! sounds like a killer all motor setup! wow on the tranny setup
Old Dec 18, 2004 | 10:31 PM
brent_G's Avatar
Default Re: my all motor build on any suggestions? (chameleon)
you rock sean!
Old Dec 18, 2004 | 10:38 PM
jaydmcrx's Avatar
Default Re: my all motor build on any suggestions? (brent_G)
Old Dec 19, 2004 | 08:08 AM
chero112's Avatar
br8crumb
17
Jan 5, 2015 07:02 AM
blacK_Dc4
Northern California (Sales)
20
Apr 15, 2010 08:30 PM
arrojj
39
Jan 24, 2007 01:43 PM
jaydmcrx
Dec 13, 2004 07:59 AM
red civic standard
Jan 20, 2003 01:29 PM
