B18A1 in Crx si?.....Is there anyway to make it work?
Old Dec 12, 2004 | 10:20 PM
Crxkustoms's Avatar
Default B18A1 in Crx si?.....Is there anyway to make it work?
Recently my cousin aquired a 91 integra....so we thought we could put it in the CRX but ran into a mount problem....is there anyway to make this work...mount wise...we have the computer and all so that is the only problem. We would reallylike this to work.
Peace
Old Dec 12, 2004 | 10:28 PM
eumoria's Avatar
Default Re: B18A1 in Crx si?.....Is there anyway to make it work? (Crxkustoms)
What you have is a non-vtec B block 1.8L callled the B18A1. It's non-OBD so it should wire up ok, you will needs mounts.
HASport makes mounts, HCP makes mounts, so do many other companies
try searching
B Series engines in Civic/CRX 88-91 is by far the most covered topic, search
Old Dec 12, 2004 | 10:31 PM
Crxkustoms's Avatar
Default Re: B18A1 in Crx si?.....Is there anyway to make it work? (eumoria)
Thanks
Old Dec 12, 2004 | 10:44 PM
GetCaughtDead's Avatar
running the exact setup in my rex now, with hcp mounts.
Old Dec 13, 2004 | 12:56 AM
31flavorscivic's Avatar
Default Re: B18A1 in Crx si?.....Is there anyway to make it work? (GetCaughtDead)
Hasport makes the mounts. My friend has this done and it is a blast to ride in. IMO get the shift linkage because people I know made their own and it kept breaking... that or do it really well the first time. Tight fit, but good luck.
Old Dec 13, 2004 | 08:57 AM
Default Re: B18A1 in Crx si?.....Is there anyway to make it work? (31flavorscivic)
modifying the shift linkage isn't hard. I'm sure a quick search will bring up anything you need to know. Besides, if you can weld, then it's free! I'd bet that most people who's linkage broke probably weren't good welders. A buddy of mine did mine, and it snapped, then a shop redid it for $15 and it's golden.
YSOFCR-VA
Oct 24, 2012 05:33 PM
-HONDA-
Mar 29, 2007 03:17 PM
g24jr
Northwest (Sales)
Mar 8, 2006 10:47 PM
Dj Lotte
Nov 29, 2002 08:07 AM
