Cut j1 jumper on ecu to bypass chip, now a/t cel on?
Old Dec 12, 2004 | 06:15 PM
so simple's Avatar
Default Cut j1 jumper on ecu to bypass chip, now a/t cel on?
ok so ive been failing smog, opened up my ecu and lo and behold, a chip. so i read through the archives and it said to bypass the chip all i had to do was cut the jumper at j1. so i did that and my car threw code 19, an automatic code, a friend of mine told me that when u cut that jumper, the ecu thinks its an automatic car. but with the jumper its a manual. so i tried to put some solder on and reconnect the jumper, dont think i did too good a job cuz cel still there, and i may have possible melted a small piece of my ecu... should i try to do a better job on reconnecting the jumper? im thinking just get another p72 obd1 gsr ecu... a chip will make me fail smog yeah?
Old Dec 12, 2004 | 07:22 PM
so simple's Avatar
Default Re: Cut j1 jumper on ecu to bypass chip, now a/t cel on? (simpleaznx)
okay reconnected the jumper so my ecu is back to its previous state, no cel lights... but a chip WILL make me fail smog because of all the extra richness it most likely runs?
Old Dec 12, 2004 | 08:09 PM
virusiidx's Avatar
it wont fail smog as long as its tuned right, or if u use your stock basemap.
as for the jumper problem, when u disconnect j1, the ecu is back to stock without using the chip. I don't know why its throwing code 19, are u sure its not an auto ecu?
Old Dec 12, 2004 | 08:11 PM
virusiidx's Avatar
thats how u can tell if its an auto or manual ecu
Old Dec 13, 2004 | 12:22 AM
so simple's Avatar
Default Re: (virusiidx)
ill open it up again tomo to recheck if its an auto or manual ecu. having an auto ecu will mess me up right? but wouldnt my car have run horribly? also the bottom right hand of the ecu is the chip correct? i think its supposed to be a skunk2 program or something. will getting a virgin ecu help me pass smog? if cutting my j1 didnt put my car back to stock ecu status, i think thats a problem
Old Dec 13, 2004 | 08:12 AM
virusiidx's Avatar
cutting j1 will return it to stock, and all the auto ecu will do is make your CEL come on, i'm currently running my auto ecu on my manual car.
B20Luder
Engine Management and Tuning
Aug 1, 2010 04:14 PM
Quarter Performance
Jul 19, 2010 05:38 PM
hawaiianhana
Sep 21, 2007 03:10 PM
b16greenmachine
Jul 27, 2007 11:32 AM
acuracy r
Jan 3, 2006 05:56 PM
