CTR CLUSTER WIRING!?
Old Dec 12, 2004 | 11:52 AM
SexyAzNMami's Avatar
Default CTR CLUSTER WIRING!?
Any wiring set up into a Crx? have difficulties.
Old Dec 12, 2004 | 12:15 PM
mrspeaker's Avatar
Default Re: CTR CLUSTER WIRING!? (SexyAzNMami)
I think that would be the same as wiring a 00-01 itr cluster..
Cant really explain how to do it..You just have to do it and match up the wires..
its a bitch..I did on my friends 91 crx si..It took us longer to wire it up then it did to swap in the motor,,and its still not workin right..
And alot of these write-ups on the web are wrong..about the obd2 gsr cluster,99-00si cluster..ITR cluster.etc..we found that out the hard way..
He should have just bought a 90-91 ukdm cluster..
Old Dec 12, 2004 | 12:29 PM
oldB18EF's Avatar
Default Re: CTR CLUSTER WIRING!? (Mrspeaker)
its not going to be the same as itr
follow this
http://faq.ef-honda.com/index....ng=en
Old Dec 12, 2004 | 01:20 PM
XJamesX's Avatar
Default Re: CTR CLUSTER WIRING!? (WR91EF)
https://honda-tech.com/zerothread?id=709958
Yea here is the link on this site. That is my write up if you have any questions just ask me. The wiring is the same. I actually did put my sisters ctr cluster in my crx but I didn't like converting KPH to MPH so I put the Si cluster back in. I have pics somwhere I just have ot find them.
Also you can not follow the civic cluster write up to install an integra cluster the wiring is different. I spent many hours comparing wiring diagrams I also know for a fact that all my wiring is correct because I swapped the civic Si cluster into my 90 si and my friends 89 si so I know the wiring is correct. The wirinf between 88-89 and 90-91 crx is different.
-James-
-James-
Old Dec 12, 2004 | 02:11 PM
HamiltonRex's Avatar
Default Re: CTR CLUSTER WIRING!? (B18C5crx)
look on the back, follow where everything goes.
If it goes to a screw labled TU its Tempunit, most will be lights, if it goes though the little denso thing on the bottom middle its for a dimmer etc..
Thtas how it was on my 99 GSR anyways.
KevinEF7
13
Jul 26, 2013 10:35 PM
daymkimchee
Mar 15, 2010 06:09 PM
I8ayellowcrayon
Apr 18, 2007 02:16 PM
Stins~b20VTEC
Nov 12, 2006 07:00 PM
