dizzy problem?
Old Dec 12, 2004 | 10:57 AM
civicdemon91's Avatar
Default dizzy problem?
ok got a 91 civic dx switchin to a d16y5 engine all i need to know is do i need to get the obd2 plugs to run this or just run my ol dizzy?
Old Dec 12, 2004 | 11:43 AM
green91's Avatar
you need to use everything off your old engine. the wiring harness, old dizzy, old injectors, everything. makes it much easier
Old Dec 12, 2004 | 01:57 PM
won't i lose power than with my ol ****?
Old Dec 12, 2004 | 02:04 PM
drdisco69's Avatar
Default Re: (civicdemon91)
Not unless it's broken. You must move all those things to the new motor to make it compatable with your ecu. The OBD2 distributor has different sensors, and won't work. The injectors are also different.
If you're worried about losing power, replace the ignition components with new OEM stuff to freshen everything up.
EGpowa
Jan 6, 2011 06:46 AM
98gsr-808-91dx
Sep 30, 2009 09:23 AM
I B BANGGIN
Feb 5, 2007 10:01 PM
flatblackhatch
Dec 17, 2005 03:10 PM
ubercerealkiller
Jan 17, 2005 08:56 AM
