Front brake upgrades
Ran across this article on an OEM upgrade that bolts right on with the exception of the rotors.
http://hybrid2.honda-perf.org/tech/bigbrakes.html
Sounds good but I don't know about having to have the rotors drilled to 4x100 each time they are changed.
So what are the low cost options for bigger brakes on a CRX?
DA's, Type R's.....
DA's, Type R's.....
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
i used a 93 GSR front knuckles, rotors and calipers on my CRX, you can also use an 90-91 civic EX front set up. it is a bolt on affair. for the GSR or any DA brakes, keep your upper control arms.
nice meeting you yesterday, BTW and can you give me that number to the re-upholstery shop?
stan
stan
Tyson
Feb 6, 2006 08:52 AM
