Need help on how to replace the front wheel stud?
Old Dec 11, 2004 | 07:28 PM
Christopherian1982's Avatar
Default Need help on how to replace the front wheel stud?
I got here a 96' honda accord and one of my front wheel stud broke off. Can anyone help me out on a step by step procedures along with some pics?
Old Dec 11, 2004 | 08:00 PM
sinister2c's Avatar
Default Re: Need help on how to replace the front wheel stud? (Christopherian1982)
take the caliper off and right behind it there is a small opening space...hammer the stud thru. install is reverse of removal.
Old Dec 11, 2004 | 08:40 PM
Default Re: Need help on how to replace the front wheel stud? (sinister2c)
Have you done it before.... are you sure thats all it take cause from what i heard, you might have to take out the hub... Some thing i heard from random people. But i really need to know who has hands on these type of situation that i have. And if all it takes is taking off the caliper i will try that out and let you know if it worked... But are positive all you have to do is remove the caliper.........
Old Dec 11, 2004 | 09:41 PM
jagged4698's Avatar
Yeah he is right. Remove the caliper and the bracket for the caliper and where the caliper goes there is an opening. pound it out and pound a new one back in. I use a ratchet extension to pound the new one back in. A lot of people think you have to take the hub off because they dont look closely enough at it. but dont waste your time
Old Dec 12, 2004 | 06:12 PM
Default Re: Need help on how to replace the front wheel stud? (jagged4698)
Hey thanks for the advice guys..... Just removing the caliper was an easy procedure. Would of cost me 100.00 if i took it to a local shop...Thanks again.
Old Mar 28, 2005 | 05:29 AM
rudeman85's Avatar
Does this also go along with a '94 honda accord? I torqued one lug to tight and now it's real loose on the wheel. Will I have problems getting it off too???
Old Mar 28, 2005 | 06:01 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Need help on how to replace the front wheel stud? (rudeman85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudeman85 &raquo;</TD></TR><TR><TD CLASS="quote">Does this also go along with a '94 honda accord? I torqued one lug to tight and now it's real loose on the wheel. Will I have problems getting it off too???</TD></TR></TABLE>
yes, this would work for 90-97 Accords.
As for getting that lugnut off, I don't know. Have you tried to remove it yet? Does it just spin? If it just spins, I've heard of people putting a little JB Weld on the back side of the stud to hold it in place while they remove the lugnut then grind the JB Weld away and remove/replace the stud.
Old Mar 28, 2005 | 06:56 AM
urbanlegend21's Avatar
New User
Default Re: Need help on how to replace the front wheel stud? (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">
As for getting that lugnut off, I don't know. Have you tried to remove it yet? Does it just spin? If it just spins, I've heard of people putting a little JB Weld on the back side of the stud to hold it in place while they remove the lugnut then grind the JB Weld away and remove/replace the stud.</TD></TR></TABLE>
Vice grips, channell locks, etc. are a little better the JB weld
dc2luva
Apr 10, 2009 03:45 PM
simonEp3
Sep 3, 2008 04:49 PM
dre2day
Feb 16, 2008 07:56 AM
The Stance
Jun 6, 2006 01:46 PM
CloudDragon
Feb 5, 2003 03:07 PM
