jdm gsr w/ ITR pistons and skunk 2 stage 2 cams??
Whats up... i am about to pick up a jdm gsr motor... and i was planning on putting ctr pistons in it and running skunk 2 stage two cams... after reading up on a few posts everyone said the compression level would be too high and might have problems as far as valves etc..... but now i am wondering if itd be safe or at least safer to use jdm ITR pistons in the gsr block w/ gsr rods, and skunk 2 stage two cams... the compression level using the ITR piston and oem headgasket on a jdm gsr would be exactly 11:3... so would using the skunk 2 stage 2 cams be ok??
eg92b16a2
Jan 15, 2006 07:54 AM
