Swaping Airbags from civic to integra's??
Ok Im not sure if this is has been brought up before, because i've searched and haven't found an answer.
I have a 94 civic drivers airbag, that i want to put into my 97 integra. But the thing is that it doesn' plug up, is there a solution to this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knightnam »</TD></TR><TR><TD CLASS="quote">Ok Im not sure if this is has been brought up before, because i've searched and haven't found an answer.
I have a 94 civic drivers airbag, that i want to put into my 97 integra. But the thing is that it doesn' plug up, is there a solution to this?</TD></TR></TABLE>
I did the same thing and I had to swap the plugs from my Acura airbag, onto the Civic airbag... You'll need to cut and solder the wires, but make sure you have a Helms available, so you connect the wires correctly...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4U2NV »</TD></TR><TR><TD CLASS="quote">
make sure you have onetwentyseven when you do it
</TD></TR></TABLE>make sure you have onetwentyseven when you do it
j87w
Aug 16, 2005 09:47 PM
