Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Integra Guys - Checkit Out . . .
Old Jan 3, 2002 | 05:55 AM
Drew M's Avatar
New User
Default Integra Guys - Checkit Out . . .
So some of us were at Summit Point and saw the World Challenge/Motorola Cup Integra with the straight out exhaust. I found these pics in the Classified forum. The system is pretty ratty but it has sparked some curiosity in regards to the design. Any thoughts?
Scott/Karl - any reason why this wouldn't be legal for the Challenge?
Old Jan 3, 2002 | 06:42 AM
Tweakmeister's Avatar
Default Re: Integra Guys - Checkit Out . . . (Cobra)
It's just as straight as possible. The car isn't going to see pot holes so clearance isn't an issue.
Old Jan 3, 2002 | 06:48 AM
Drew M's Avatar
New User
Default Re: Integra Guys - Checkit Out . . . (Tweakmeister)
I didn't realize there would be as much room as there is under there.
Old Jan 3, 2002 | 06:51 AM
krshultz's Avatar
Running the exhaust directly under the gas tank leads me to believe that this car may do something spectacular soon.
The only fix I see is to install some of these:
Old Jan 3, 2002 | 06:54 AM
Honda318dx's Avatar
Default Re: Integra Guys - Checkit Out . . . (krshultz)
That is probably one of the many reasons why it is heat wraped...
Old Jan 3, 2002 | 06:57 AM
Drew M's Avatar
New User
Running directly under is different from running right next to it because?
Old Jan 3, 2002 | 07:06 AM
Xian's Avatar
b/c heat rises actually I would guess that running it under the tank allows the heat coming off of the pipe to transfer to a larger section of tank than if only the end of the tank is exposed to the exhaust heat. IMO though, it won't matter too much as this is a race car and is not going to be puttering around in stop and go traffic on 100 degree days in Texas... seems that the benefits would make it a worthwhile mod.
Old Jan 3, 2002 | 07:22 AM
krshultz's Avatar
Is it actually right next to it? I don't remember. And it's too cold in the garage for me to go look.
Old Jan 3, 2002 | 07:35 AM
Warren's Avatar
Wrong-Way Wang
You won't pass sound like that. You know that! Gotta point that bad boy down behind the driver.
Warren
Old Jan 3, 2002 | 07:39 AM
johng's Avatar
I haven't completely read through your HC rules, but is there something saying that the exhaust must exit or terminate at the back of the car? I was thinking about using something like this picture bolted directly to the header for my car. The down-turn would be about in the middle of the car.
Old Jan 3, 2002 | 07:41 AM
Drew M's Avatar
New User
Maybe not right next to it but definately within 2 inches of the tank.
Warren - if I point it straight down I won't be able to put a muffler on and therefore it won't pass sound.
Old Jan 3, 2002 | 07:56 AM
krshultz's Avatar
Sitting in the paddock idling with the exhaust located there is what would make me nervous.
Old Jan 3, 2002 | 07:57 AM
Brian*'s Avatar
just find some sort of straight through muffler of your desired size (inner diameter) and weld on a mandrel bent downturn, between like 90degrees and 45degrees for an angle of the bend. Thats what RE Amemiya does with their RX7 exhausts when they are on track to keep noise down
Brian
Old Jan 3, 2002 | 09:12 AM
Catch 22's Avatar
Default Re: Integra Guys - Checkit Out . . . (Lemon Drop)
Several things...
Most rules state simply that the exhaust must terminate behind the driver. This is a carbon monoxide safety thing.
Noise. Summit Point is the scary one. My car with a straight through exhaust has registered as high as 108dbs. This is over the limit at both Roebling and Summit.
I have planned some changes for my exhaust to try to get below 100dbs. The current plan is to add a 90 degree bend and terminate it in front of the right rear wheel.
Also, I don't like the way that exhaust pictured hangs below the car. You could destroy it in an otherwise harmless off into bumpy terrain. It could also hang up loading on to many trailer designs.
There is a recessed tunnel under the car where the stock exhaust lived. I suggest keeping anything you do in that tunnel.
Germizzooo
Oct 24, 2011 11:14 AM
RICKSAUTOMOTIVE
Apr 23, 2010 01:48 PM
InTheLBC20
Feb 13, 2009 09:52 AM
move_right
Oct 15, 2004 10:30 AM
MugenB18cTeC
Jun 12, 2004 11:43 AM
