ABS effectivness with larger rims
Old Dec 11, 2004 | 04:15 PM
Fink2iCe's Avatar
Default ABS effectivness with larger rims
Bigger rims look nice and probably are better for track use (?). But I hear that bigger rims effect the ABS functionality in a negtive way since ABS works by sensing the speed at which the wheels are spinning (bigger wheels need less revolutions to cover the same distance as smaller wheels).
Or am I just talking nonsense here? Since the overall diameter of the wheel (including the tire) would be the same, just that the tires on the bigger rims will be low profiles.
Old Dec 11, 2004 | 04:27 PM
Holding monSteR's Avatar
Default Re: ABS effectivness with larger rims (Fink2iCe)
as long as you upsize properly the difference in overall diameter should be kept to a minimum, thereby affecting the wheel speed very little.
Old Dec 11, 2004 | 04:40 PM
uNF$@#!'s Avatar
alex, can I have generalizations for $200?
Old Dec 11, 2004 | 05:10 PM
George Knighton's Avatar
H-T Order of Merit
I've had hard use of ABS on the track with both 215-45-16 tyres and 205-50-15 tyres, and the ABS performed magnificently with both sizes.
Old Dec 11, 2004 | 05:57 PM
ZygSpeed's Avatar
ABS works by sensing the difference between wheel speeds!
The numbers themselves don't really matter, otherwise the ABS (system) would be speed dependent.
young noob #2
16
Oct 10, 2008 09:38 AM
skingfreak
Mar 28, 2007 04:17 PM
itsblue98
Mar 24, 2006 06:11 PM
psegs80
Dec 25, 2005 05:05 AM
2camsaam
Oct 3, 2003 07:29 AM
