Automatic B-series motor into manual EF
Old Dec 11, 2004 | 02:52 PM
libila's Avatar
Default Automatic B-series motor into manual EF
Are there any physical differences between a B-series automatic motor and a B-series manual motor? Are the engines designed the same way?
A local has offered to sell me an automatic integra and I want to know if I can use the motor out of it? If this happens, I plan on using the close ration b16 transmission with a limited slip differential. Can anyone forsee any problems in doing this?
Old Dec 11, 2004 | 03:11 PM
drdisco69's Avatar
Default Re: Automatic B-series motor into manual EF (libila)
The motor is the same but the cams are teh suk and it's got shitty valve springs You'll want all that out of there if you want to do anything.
Old Dec 11, 2004 | 10:01 PM
libila's Avatar
The motor will match up to a manual transmission with no problems, correct?
The engine mounts the same, and all the wiring is the same, correct?
Old Dec 12, 2004 | 07:19 AM
drdisco69's Avatar
Default Re: (libila)
Yeah, my friend has an auto B16 in his integra with a manual transmission, everything is the same. Like I said though, the cams are weaker, and it's got single valve springs on the exhaust side, so before you try to rev any higher or put better cams in, you should at least put an ITR valvetrain in there. The motor bolts in exactly the same though. Of course you'll need the flywheel and clutch if it doesn't come with it, but thats it.
Old Dec 12, 2004 | 07:34 AM
libila's Avatar
That's exactly what I needed to know, thanks.
Old Dec 13, 2004 | 03:59 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by libila &raquo;</TD></TR><TR><TD CLASS="quote">Are there any physical differences between a B-series automatic motor and a B-series manual motor? Are the engines designed the same way?
A local has offered to sell me an automatic integra and I want to know if I can use the motor out of it? If this happens, I plan on using the close ration b16 transmission with a limited slip differential. Can anyone forsee any problems in doing this?</TD></TR></TABLE>
You make no mention of exactly what kind of B-series motor you are talking about. But if it is a USDM Integra, there is one thing to consider: The automatic LS motors use a different intake manifold. Specifically, it has provisions for EGR. You want to get rid of this. But I am not sure about cams in a non-VTEC motor. As for using a manual transmission, you just need to get the flywheel and clutch to mate it up.
Old Dec 13, 2004 | 08:53 AM
libila's Avatar
Default Re: Automatic B-series motor into manual EF (StorminMatt)
The motor I'm speaking of is a B18a. I've heard about the intake manifold differences, but I wasn't sure.
aziaticvang
Mar 23, 2009 02:53 PM
hondacivic90zc
Sep 10, 2007 03:09 PM
ej1civic
Apr 2, 2003 04:01 AM
ej1civic
Apr 1, 2003 06:45 PM
ej1civic
Mar 31, 2003 07:00 PM
