aftermarket steering wheel with "cancel turn signal"?
Old Jan 3, 2002 | 04:04 AM
citanest's Avatar
New User
Default aftermarket steering wheel with "cancel turn signal"?
How do you make the "cancel turn signal" to work after installing the aftermarket steering wheel? Does it depend on the build of the hub or there is a way to work around it? thanks
Old Jan 3, 2002 | 06:25 AM
yoshi234's Avatar
I shoot brides
Default Re: aftermarket steering wheel with "cancel turn signal"? (citanest)
you brought up an interesting question.
ITR607(robert) and I have the same MOMO steering wheel and hub. The turn signal cancels on my car (00 spec), but not on his (98 spec). One of these days, we'll have to take off the hub and see what's causing this diff.
-y
Old Jan 3, 2002 | 08:26 AM
sgT's Avatar
sgT
The hub doesnt sit far enough in to touch the canceler system.
You have to grind out the hub to allow it to go farther in and use washers
behind the nut.
Old Jan 3, 2002 | 08:47 AM
travis's Avatar
Default Re: aftermarket steering wheel with "cancel turn signal"? (sgT)
I recently installed an OMP hub and wheel. I didn't do anything special to make anything work, and the cancel turn signal function works fine.
-231, who's thankful that at least one potential snag has passes him by.
Old Jan 3, 2002 | 09:44 AM
formulaR6's Avatar
There should be two notches on the back of the hub this will line up with the turn signal piece on the steering column to turn the signal off.
see vick
12
Mar 5, 2021 05:49 AM
Synapz
Honda Civic (2001 - 2005)
15
Jul 26, 2007 12:08 PM
