GUMMY SHIFTING
Old Jan 3, 2002 | 03:44 AM
Turtle's Avatar
Default GUMMY SHIFTING
When I change gears the shifter seems a little more gummy; less smooth I guess. Could this be a condition from not changing trany fluid? I'm at 20k on the same fluid; when should I change it?
And on another side issue; what's the best way to get out ALL of the trany fluid? I know that some mechanics have machines that will "flush" out all of the old and replace with new fluid, but how can I do this at home? Any special tools needed?
Thanks for your help.
- B
Old Jan 3, 2002 | 03:55 AM
MiraiZ's Avatar
Default Re: GUMMY SHIFTING (401-2001)
tranny fluid on a manual?....do u mean gear oil?
Old Jan 3, 2002 | 04:18 AM
Willard's Avatar
Honda MTF is your friend...
A complete flush would require the tranny to be tore down.
Just flush with the 2.2-2.3 qts and you will be fine.
Easy flush at home (just like changing the oil... w/o the filter)...No special t00ls needed.
FYI.. the cold weather has a lot to do with the shifting stiffness.
Will
Old Jan 3, 2002 | 04:28 AM
seek167's Avatar
Default Re: GUMMY SHIFTING (Willard)
could be the cold too.is it all day or just for the first 1/2 hour
every 15000 miles
[Modified by seek167, 8:29 AM 1/3/2002]
Old Jan 3, 2002 | 05:09 AM
Turtle's Avatar
Default Re: GUMMY SHIFTING (seek167)
Cold could be affecting it, yes. So basically changing the fluid when I do a valve adjustment would be good then, right?
Old Jan 3, 2002 | 05:15 AM
Willard's Avatar
That would be fine... every 15000 should be fine pending usage.
Will
-who has flushed his 4 times in 26000 miles.
CRP
Nov 5, 2017 01:06 PM
916B18c1
Jun 30, 2008 04:22 AM
globy123
Dec 17, 2006 07:20 PM
kornerk12
Nov 18, 2005 05:37 AM
DeDonDeRosa
Jul 30, 2002 01:08 PM
