which cam gears are better
Old Dec 11, 2004 | 12:36 PM
wingswestrex's Avatar
Default which cam gears are better
imma be running an ls turbo
golden eagle
skunk2
darkside racing
hayame
aem
hks
let me know which ones are better and dont just pick them cause of the name please
thanks a lot
Old Dec 11, 2004 | 01:41 PM
ELAMINT5's Avatar
Default Re: which cam gears are better (wingswestrex)
i use skunk2... more bolts to hold the gear in place. I used AEM on my last car and it they came unscrewd. AEM SKUNK2 but those are the only two that I have ever used
Old Dec 11, 2004 | 01:56 PM
Default Re: which cam gears are better (ELAMINT5)
thanx for the reply man, the guy who had my car b4 me had a diff. motor in it with hayame cam gears, and he said they were pretty good, i can get the golden eagle and darkside, and the hks pretty cheap, same with aem, but as we all know cheap isnt whut makes a motor, u pay for whut u get
Old Dec 11, 2004 | 02:25 PM
drdisco69's Avatar
I like my STR gears, once you get the hang of the degree system they use it's very easy to set, and 5 actual bolts, not some easy to strip allen head cap screws. I got mine from http://www.inlinefour.com a while ago.
Old Dec 11, 2004 | 06:38 PM
non-VTEC's Avatar
i use crower cam gears. they have ARP locking bolts NOT allen key heads like you find on AEM or skunk gears which will probably strip out.......also they torque down nice and wont slip.....
Old Dec 11, 2004 | 07:10 PM
2k.civic.si's Avatar
Default Re: which cam gears are better (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i use crower cam gears. they have ARP locking bolts NOT allen key heads like you find on AEM or skunk gears which will probably strip out.......also they torque down nice and wont slip..... </TD></TR></TABLE>
my aem gears arent allen? they have 8mm arp bolts...4 years old...never slipped....they see 10,000 rpm on occasion to...bought from and installed by midnightperformance
Old Dec 11, 2004 | 07:13 PM
non-VTEC's Avatar
Default Re: which cam gears are better (2k.civic.si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">
my aem gears arent allen? they have 8mm arp bolts...4 years old...never slipped....they see 10,000 rpm on occasion to</TD></TR></TABLE>
must be a newer design then the ones i had before...... i stand corrected
Old Dec 12, 2004 | 04:47 PM
ok everyone thanks for the replies, i never knew crower made cam gears, i thought it was just everything else
im thinking bout either going with darkside racing, or hayame
whuts every1think or heard bout those let me know
Old Dec 12, 2004 | 06:42 PM
v4lu3s's Avatar
RTFM
also check out fidanza cam gears they are very nice.
Old Dec 12, 2004 | 08:32 PM
PrettyLude's Avatar
str is pretty good
Old Dec 12, 2004 | 09:05 PM
N2O's Avatar
N2O
Default Re: (PrettyLude)
I have used just about every set of gears there on various motors. My favorites have been the HKS and the STR the befits are the same but the way they are achieved is very different.
The HKS uses stock Honda gears with the centers machined to accept a aluminum adjustable center section. Very nice gears but also very expensive.
STR makes probably what I think to be the best all aluminum completely aftermarket gear out there. They use a special process to make there gears that makes them much more accurate than a CNC gear from other companies. After taking a tour of there plant and talking to Scott in detail about STR gears and how they are made I do not think that I will every put another set of gears on any of my motors. Plus that bronze color is just plain out awesome looking.
My 0.02
-Duck-
Old Dec 12, 2004 | 09:39 PM
PrettyLude's Avatar
bronze color is very awesome
Old Dec 12, 2004 | 09:54 PM
milton's Avatar
jg seems to be very good i have had no problems with them
Old Dec 13, 2004 | 02:50 PM
Default Re: (milton)
thanks everyone, looks like i mite be looking into str then thanks for the write up n20
Old Dec 13, 2004 | 04:01 PM
Padawan's Avatar
Darth ModerVader
Default Re: (wingswestrex)
ST Corsa are the only ones I'd recommend.
Old Dec 15, 2004 | 03:10 PM
Default Re: (N2O)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N2O &raquo;</TD></TR><TR><TD CLASS="quote">I have used just about every set of gears there on various motors. My favorites have been the HKS and the STR the befits are the same but the way they are achieved is very different.
My 0.02
-Duck-
the reps from spoon said only cam gears they would run besides their own are str
Old Dec 15, 2004 | 04:21 PM
Phaze*2_Mizzark's Avatar
my friend uses skunk 2 cam gears.. he loves them
Old Dec 15, 2004 | 05:57 PM
Gump's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">ST Corsa are the only ones I'd recommend. </TD></TR></TABLE>
http://www.hogens.com/showpart.php?id=005
Old Dec 15, 2004 | 06:53 PM
Beezer's Avatar
toda's cam gears
Old Dec 15, 2004 | 08:47 PM
Big Teggie's Avatar
Default Re: which cam gears are better (Beezer)
ST Corsa
Old Dec 15, 2004 | 09:22 PM
itralex's Avatar
Default Re: which cam gears are better (Big Teggie)
I'm running St Corsa
Old Dec 15, 2004 | 11:08 PM
Wht-Blk dc2's Avatar
cant recommend any specific 1, but skunk2 and hks hasnt gone wrong here.
Old Dec 16, 2004 | 09:57 AM
SCYRIO's Avatar
Default Re: which cam gears are better (Wht-Blk dc2)
THE BEST ARE JG (EDDLE BROCK) CAMS AND SKUNK 2 CAM GEARS
THEY HAVE A 6 POINT AJUSTABLE BOLT FOR THE BEST HOLD
I HAVE THEM AND THEY ARE AWSOME.. AEM IS NOTHING BUT CRAP WITH 3 POINT AJUSTABLE AND THEY WILL EASILY CRACK ON YOU.. SERIOUS!!
Old Dec 16, 2004 | 11:22 AM
rhd's Avatar
rhd
SRR
same as skunk2, but a HELL of a lot cheaper...and they're purple!!!!!!!
Old Dec 16, 2004 | 02:30 PM
Big Teggie's Avatar
Default Re: which cam gears are better (SCYRIO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCYRIO &raquo;</TD></TR><TR><TD CLASS="quote">THE BEST ARE JG (EDDLE BROCK) CAMS AND SKUNK 2 CAM GEARS
I HAVE THEM AND THEY ARE AWSOME.. AEM IS NOTHING BUT CRAP WITH 3 POINT AJUSTABLE AND THEY WILL EASILY CRACK ON YOU.. SERIOUS!!</TD></TR></TABLE>
You cant get a better hold than the ST Corsa gears with their shoulder lock design. They will never slip.
I had a set of Skunk2 gears and the allen keys started to strip.
