What's wrong with my car?
Old Dec 11, 2004 | 11:33 AM
KingJeff's Avatar
Default What's wrong with my car?
For the past few months, every so often my car would take a while to start. IT would turn over for a second. Sometimes wouldnt turn over and just make a clicking sound. But last night, it wouldnt start. Just click. So I tried to jump it, but it didnt work. Is it my battery? The lights and radio still worked. BUt we jumped it again a few hours later and worked. My friends think it may be the starter. What do u guys think?
Old Dec 11, 2004 | 12:28 PM
xxtegra's Avatar
Default Re: What's wrong with my car? (Jeff K.)
maybe the main fuel relay under the dash
take it out and if you see ne crack in the soder
soder it if so
Old Dec 11, 2004 | 12:55 PM
CrAzyGsR101's Avatar
Default Re: What's wrong with my car? (xxtegra)
Its the starter I am 100% sure.
Old Dec 11, 2004 | 01:49 PM
CBRF4i's Avatar
Default Re: What's wrong with my car? (CrAzyGsR101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrAzyGsR101 &raquo;</TD></TR><TR><TD CLASS="quote">Its the starter I am 100% sure.</TD></TR></TABLE>
Yep. And if your in a pinch and your car wont start hit the starter with a stick or something while someone tries to start it. Should get one or two good starts out of it before it completely ***** the bed on you Plus theres always the infamous push start
Old Dec 11, 2004 | 04:32 PM
bravoecho11's Avatar
Default Re: What's wrong with my car? (CBRF4i)
Push Starting. .. . I have done my share of them. Push starting AWD DSM's sucks.
Old Dec 11, 2004 | 04:39 PM
KingJeff's Avatar
Default Re: What's wrong with my car? (bravoecho11)
hmmm, well I guess I will have to buy a new starter. My bro also said it could be the alternator belt. Could that be a possiblility?
Old Dec 11, 2004 | 05:31 PM
4U2NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff K. &raquo;</TD></TR><TR><TD CLASS="quote">hmmm, well I guess I will have to buy a new starter. My bro also said it could be the alternator belt. Could that be a possiblility?</TD></TR></TABLE>
Well a bad alternator will drain the battery faster, so it could be possible that's why your battery is dead... I'd say replace the battery first, then if the new battery dies you've got something else going on... Just make sure the battery you purchase has some kind of warranty...
The cost and time of changing a battery &lt; the cost and time of changing an alternator...
Old Dec 11, 2004 | 07:41 PM
Default Re: What's wrong with my car? (4U2NV)
I am telling man it's not the battery its the starter go buuy one it shouldnt take more than 45 mins to put it on dont go waste money on a batt.
Old Dec 11, 2004 | 08:43 PM
b-power's Avatar
pretty sure it is the starter
Old Dec 11, 2004 | 10:40 PM
Stripped Honda's Avatar
99-0104
Default Re: What's wrong with my car? (b-power)
its the starter ..... not the main relay and not the main relay ... if your short on money you can rebiuld it very easily .. all you need is some copper ... it will save you alot of money ...
Old Dec 12, 2004 | 01:17 AM
yeegsr's Avatar
bad guess but a good possibility.....get ur starter to Kragen or Auto and check or self-check
unhook NEGATIVE(black) from main battery....on the starter, look for a jump or connector that goes from the batter to ur starter....then unhook it....chekc the connector...if any dirt or dust or ruste ...brush them off.....get sandpapers or anything that can renew the metal to make it conduct better than do it....and hook it back in....
*CHECK ALL OTHERS GROUND WIRES....damage or rust....replace them...ground wires are very vital to the motor too
Old Dec 12, 2004 | 05:48 AM
sleevedgsr's Avatar
Same exact thing happened to me it is for sure your distributor! Its not to much to get fixed. Cost me about 150 all you need basically is a new ignitor and it should work perfectly!
DriveSlowHomie
Jan 26, 2010 10:31 PM
pepper
Sep 21, 2007 07:27 PM
oldschoolfreak
Jan 16, 2005 08:25 PM
SalmanzCivic
Jan 4, 2005 09:14 PM
xkhalil333x
Oct 16, 2003 06:16 AM
