CTR pistons in an b18c5.. question
Old Dec 11, 2004 | 10:06 AM
Eg_TypeR's Avatar
Default CTR pistons in an b18c5.. question
I have a 2001 type r motor, i have bored out the cylinders a little, and have installed oversized JDM CTR pistons.. I am planning on using a stock headgasket and a stock R head..... Will i be running to much compression??? Has any one done this set up before??
Old Dec 11, 2004 | 10:46 AM
Evil DOHC's Avatar
Default Re: CTR pistons in an b18c5.. question (Eg_TypeR)
You wont be running too much compression, but make sure you do something for the fueling of that motor. I got a stock setup like that running right now, dynoed 180 to the wheels all stock except for the ctr pistons standard bore.
EVIL
Old Dec 11, 2004 | 11:32 AM
Bbasso's Avatar
even something as simple as that, you should consider getting yourself a ECU and dyno time to prevent any possible headaches in the future.
Good luck
Old Dec 11, 2004 | 11:59 AM
Dogginator's Avatar
Daisy... Daisy...
This link has some information of interest to you:
http://www.lightningmotorsports.com/techpiston.htm
Old Dec 12, 2004 | 05:50 AM
6ghatch's Avatar
Default Re: CTR pistons in an b18c5.. question (Dogginator)
The compressions will be closer to 12.6 to 1. You will most likely need and engine management system to tune back ignition timing or else you will need to adjust your base timing way back if you plan to run pump gas.
https://honda-tech.com/zerothread?id=717928
onewayoutcity
May 25, 2009 01:06 PM
I AM WEASEL
Nov 15, 2007 06:11 AM
Amused
Nov 12, 2005 03:54 PM
Eg_TypeR
Dec 12, 2004 10:54 AM
toohott4handlin
Jan 19, 2004 05:21 PM
