OK guys, did a search.... for awhile... ITR valvespring specs???
Old Dec 11, 2004 | 08:39 AM
Shawn C's Avatar
In The Garage
Default OK guys, did a search.... for awhile... ITR valvespring specs???
i know somebody on here knows.... what pound rating do ITR springs have?? i'm workin on a little motor project, and i need to know if i should upgrade the springs for higher revving. thanks
-Shawn
Old Dec 11, 2004 | 09:29 AM
Reid's Avatar
Global Moderator
Default Re: OK guys, did a search.... for awhile... ITR valvespring specs??? (ShadyEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyEH2 &raquo;</TD></TR><TR><TD CLASS="quote">i know somebody on here knows.... what pound rating do ITR springs have?? i'm workin on a little motor project, and i need to know if i should upgrade the springs for higher revving. thanks
-Shawn</TD></TR></TABLE>
I can't remember the specs of the ITR valvesprings off hand, but if you tell us which camshafts you intend to use we can figure out if you need to upgrade your valvesprings or not.
Old Dec 11, 2004 | 09:43 AM
Victor Penner's Avatar
Default Re: OK guys, did a search.... for awhile... ITR valvespring specs??? (Reid)
Installed seat pressure- 50 lbs.
11mm. lift- 140lbs.
11.5mm. lift-150lbs.
12mm. lift- 158 lbs. (bind)
12.5mm. lift- BIND
11.5mm. lift- 20k left before bind.
Installed height- 1.320"
This information is from http://www.importreview.com
Victor Penner
Alloy
Suspension & Brakes
Jun 28, 2007 03:15 AM
HatchSpeeD
Apr 9, 2006 05:52 PM
Wazup
Suspension & Brakes
Mar 9, 2005 11:39 AM
. o 69 o .
Jun 4, 2003 11:34 AM
gsxr
Oct 17, 2001 07:25 PM
