Oil dripping from Y-pipe
Old Dec 10, 2004 | 11:42 PM
OneDirection's Avatar
Default Oil dripping from Y-pipe
Car is 96 GSR. Car ran fine and never dripped oil previously. I noticed a smell of oil when driving, but didn't have a chance to investigate when I got home
I pulled it back and there was a good sized pool of oil where the car had been. Oil appears to be dripping down the left side of the Y-pipe. The filter that was on seemed loose, so I did a complete oil change and filter change with no luck. Any other ideas? The engine runs fine otherwise.
Old Dec 11, 2004 | 12:22 PM
Default Re: Oil dripping from Y-pipe (OneDirection)
I wasn't able to torque the filter all the way, but it doesn't quite seem like it's the filter area leaking.
Old Dec 11, 2004 | 12:39 PM
ChillOutWayne's Avatar
keep an eye on the filter area, if thats leaking it lands right on the y pipe.
spray the **** outta the area with brake cleaner, and investigate often afterwards
Old Dec 11, 2004 | 12:44 PM
LSvtec03's Avatar
Default Re: Oil dripping from Y-pipe (ChillOutWayne)
oil pan gasket, maybe?
Old Dec 14, 2004 | 07:55 AM
Default Re: Oil dripping from Y-pipe (LSvtec03)
You were a winner if you guessed:
Oil pan
The exhaust was installed by a numb**** who had the exhaust rubbing the oil pan. This caused it to rub a dub dub against it, creating a hole for the oil to pee out onto the Y pipe.
So now I need an exhaust from where it hits the engine all the way back.
Old Dec 14, 2004 | 09:03 AM
So I checked a little more vs service manual. It appears the genius used a b18b exhaust on a b18c1 engine. The O2 sensor is before the cat, but in the manual, it's in the cat. I think I'm going to try to get the entire exhaust from manifold to exhaust tip back off a used car, replace all gaskets and fasteners, repaint, and install it.
Old Dec 14, 2004 | 09:46 AM
LSvtec03's Avatar
what do i win? j/p. glad you got it sorted out
Old Dec 16, 2004 | 06:33 PM
Well you said the gasket, but there's a hole in the pan Close, but no cigar
Old Dec 17, 2004 | 07:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OneDirection &raquo;</TD></TR><TR><TD CLASS="quote">Well you said the gasket, but there's a hole in the pan Close, but no cigar </TD></TR></TABLE>
thats always nice
rsangha13
Apr 20, 2013 07:15 AM
///Nick
Jul 10, 2012 11:42 PM
briq4
Honda Civic (2001 - 2005)
11
Aug 17, 2009 04:30 PM
Iomega01
Mar 25, 2006 09:07 AM
redGSRguy
Aug 10, 2002 01:01 AM
