Stock Bose Sub Wiring Questions
Anyone have a wiring diagram for the stock spare mounted Bose sub? Trying to install an amp and a 10" Eclipse sub without buying an aftermarket deck, assuming two of the 4 wires in the stock harness are power/ground and 2 are signal... Let me know
So the yellow and purple are the signal wires, and the black is ground, green and red are both power? I'm gonna try and use one of em as the remote turn on lead...Anyway thanks for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludeR917 »</TD></TR><TR><TD CLASS="quote">yellow - bass (-) signal
purple - bass (+) signal
black - ground
green - woofer
red - woofer</TD></TR></TABLE>
thats wrong. I've wired this to a eg.
black - ground
green - woofer
Just my opinion here, but if you want a good system then you should use after market power/ground wires. Those wires are way too small to use for any descent wattage amp. Just make sure your amp can take the speaker input wires for it's signal
What are you guys trying to do though?
we wanted to run on amp on high level inputs or put a high level to low level adapter using the sup output. thats all i wanted to knoe is which wire is the sub+ and sub- thats all i really need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznbo1626 »</TD></TR><TR><TD CLASS="quote">
thats wrong. I've wired this to a eg.</TD></TR></TABLE>
i have the wiring diagram right in front of me, i dont know what to say.
after readin your post again, i think the easiest way is to get the remote wire from the stock deck. its the brown wire. and use the yellow and purple as signal wire to your amp. the green and red wire are the sub high output. let me know if that helps.
sniperslayer
11
Dec 6, 2004 07:34 PM
