Making speedo work with H22 swap?
Old Dec 10, 2004 | 04:59 PM
1point7db2's Avatar
Default Making speedo work with H22 swap?
Does anybody have any ideas to make my speedo work? Of course the stock speedo is cable while the H22 is electronic. Could I swap to a gs-r or itr cluster and make it work that way?
Old Dec 10, 2004 | 05:29 PM
1point7db2's Avatar
Default Re: Making speedo work with H22 swap? (h22rexguy)
nobody?
Old Dec 10, 2004 | 05:30 PM
eumoria's Avatar
h22 is electronic VSS, like any b-series swap
you need to use a electronic speedo cluster from a 99-00 civic, or an integra one, or something like that
like this http://www.ef-honda.com/main/viewtopic.php?t=1400 from a cool guy who lives near me... sold me a CRX Si dash, awesome dude... and a good writeup
Just disreguard the cable to electronic sensor changover and just look at the cluster stuff. My brother did a 99 Civic EX Manual cluster in his 90 DX w/ B16... looks and works awesome.
Old Dec 10, 2004 | 05:37 PM
K-Drum's Avatar
you can do 2 thing to get this to work.
you have to pull what's left of the EVSS out of the H22 tranny, and you will need the little gear off the H22 one ( held in with a small clip) remove your D-series gear off you cable and install the replacment H22 one. install as usual.
OR
buy a new Cluster with EVSS (like a Type-R) and do a Cluster swap with a EVSS... it will need a little wiring but nothing major.
Kun
Old Dec 10, 2004 | 05:58 PM
doublethink's Avatar
Default Re: (K-Drum)
your both forgetting an sir cluster, has EVSS, but yea i used and EK 98 EX Sedan 5 speed cluster, works fine, looks clean, and the speedo worked with my electronic vss from the XSI b16 swap.
you need either an SiR cluster, or a 92+ to make it work. good luck!
Old Dec 10, 2004 | 06:33 PM
ImportRicer's Avatar
Default Re: (doublethink)
yeah..change the wirings
Old Dec 10, 2004 | 07:52 PM
K-Drum's Avatar
i just said Type-R because I have a DC2 cluster in my hatch waiting to get installed in my CRX.
flipmoderacing1
May 3, 2012 04:29 AM
92civlude
May 8, 2009 11:35 AM
under_psi
May 13, 2004 05:37 AM
