What do you use to cut the square or hole in logs?
I just welded up my 2nd log mani, and instead of having a pipe extended from it to the turbo flange, I just want to weld the turbo flange right to the log. Should I cut a square in it to sink the turbo flange in it? What would you use to cut a square in it???
Or just use a hole saw and kinda fill in the gaps on the sides?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx »</TD></TR><TR><TD CLASS="quote">I just welded up my 2nd log mani, and instead of having a pipe extended from it to the turbo flange, I just want to weld the turbo flange right to the log. Should I cut a square in it to sink the turbo flange in it? What would you use to cut a square in it???
Or just use a hole saw and kinda fill in the gaps on the sides?</TD></TR></TABLE>
i would prob use a plasma cutter and a good hand .. or i would have cut it befor it was welded .. and use this babe to mount the turbo flange to the manifold
u can get it here .. http://www.jgstools.com
or u could prob make your own if u have acces to a mill .. its basicly just a noched round edge reqtangle stock
My work might have a plasma cutter, I forget if the welder took it with him when he retired or not. That was my first thought too, I'm going to look into that either tonight or tomorrow.
I know you like to do all your own work, but if you don't have access to a mill, a machine shop could do this for you in about an hour.
That is, if I'm thinking of the right part, I'm not sure what a log manifold is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goullish »</TD></TR><TR><TD CLASS="quote">I know you like to do all your own work, but if you don't have access to a mill, a machine shop could do this for you in about an hour.
That is, if I'm thinking of the right part, I'm not sure what a log manifold is.</TD></TR></TABLE>
Now that's not a bad idea, I never even thought of that. Just take it to them with it outlined in sharpee or something, and tell them to cut it out. ****, it might be cheap, like only $20 or something too. I'll have to look into that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx »</TD></TR><TR><TD CLASS="quote">Now that's not a bad idea, I never even thought of that. Just take it to them with it outlined in sharpee or something, and tell them to cut it out. ****, it might be cheap, like only $20 or something too. I'll have to look into that.</TD></TR></TABLE>
also high school metal shops are your friend
.. when ever i need simple **** i go to my highschool shop and donate a tool i dont use like a file or hammers .. teach lets me in there to do some milling ..
Ummm unless you live in bumblefuck, you'll be hard pressed to find a shop with a rate of anything NEAR $20/hr. Your local redneck maybe.....
Most shop rates are $40/hr on the low end and $70/hr on the high end for most with the exception of a few big cities.
Just a heads up, thats all. If you can get it done for $20, more power to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anthonycn »</TD></TR><TR><TD CLASS="quote">What I do is use a 4 1/2 grinder with a cut off disc. Just cut a rectangle to match the flange and just weld it on.</TD></TR></TABLE>
That's what we did too
Well I wussed out and basically made one of these out of some square steel (I dont know the technical name
) I'll post up some pics in a new thread of something when I'm finished
