turbo vs. turbo ls
Old Dec 10, 2004 | 04:20 PM
jlong17crx's Avatar
Default turbo vs. turbo ls
I have a 91si crx w/ a turbo zc motor! I also have a ls motor,tranny,harness,and ecu. Should i keep the turbo zc and sleeve that motor or should i go with the ls and turbo it. Im only running about 7lbs on the zc and i want to run alot more but then i would need to sleeve it and what not. Im just not to sure if the ls is worth it? If i think that i may want the zc still i can use the ls in my other crx but im trying to have a daily driver that will not break down!Any ideas will help at this point before i spend all my money
Old Dec 10, 2004 | 04:23 PM
GoFastMotorSports's Avatar
Default Re: turbo vs. turbo ls (jlong17crx)
https://honda-tech.com/zerothread?id=619564
^^^Go there^^^ I am a SOHC lvoer and will always rock SOHC but.... A stock ls block with rods and pistons blew up at 20psi. So at 14-15 psi daily driving he was fine. Thats some good **** right there. And the only reason it blew up IMO is cause he ws running they ghey hack at 20 psi...
Modified by GoFastMotorSports at 8:35 PM 12/10/2004
Old Dec 10, 2004 | 04:41 PM
jlong17crx's Avatar
Thanks, i think im going to sleeve the zc and get a t3, now i have a t25 on there, I just want it to all be perfect w/ as much boost as possible. I now the block will hold it but not the tranny! I donno...
Old Dec 10, 2004 | 05:03 PM
libila's Avatar
You should sell me your LS components for cheap
panchlow
20
Jun 13, 2011 05:07 PM
the king.
35
Nov 26, 2006 01:51 PM
killablaze
Oct 7, 2005 04:06 PM
xfrankx
Aug 18, 2005 06:21 PM
crxzc
12
Jun 26, 2002 10:21 AM
