wheel hoppin
my car tends to wheel hop alot especially in rain is it maybe my tires or because I have a swap and the front of my car is heavier than it should be. I have 17 inch Yokohamas seasonals on right now
From: Salt Lake City, Chicago at heart, UT or IL, USA
are you currently on stock suspension? If so, that would most likely be your problem. Anyways, you shouldn't be accelerating that fast when it's wet. The wheel hop is trying to tell you something...
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
motor mounts, front end bushings, and front crossmember will pretty much eliminate your problem.
