b18c swap on 91 civic hatch?
Old Dec 10, 2004 | 02:00 PM
96tegsr's Avatar
Default b18c swap on 91 civic hatch?
What do i need to pass CA smog if i swap a b18c1 on a 91 hatch? Im asking this question for my friend because hes just worried about smog? any input on whats the best enging to swap in it so he can have a little more power and still pass smog..?
Old Dec 10, 2004 | 02:05 PM
dr_latino999's Avatar
Default Re: b18c swap on 91 civic hatch? (96tegsr)
Needs to be OBD-1 and contain all functioning emissions equipment that the GSR had. Also, it helps if it is clean within the bay and everything looks OEM. If you look around this forum there have been a couple of members who have just recently BARed there motors.
Old Dec 10, 2004 | 02:10 PM
96tegsr's Avatar
Default Re: b18c swap on 91 civic hatch? (dr_latino999)
what about b16? its gonna be a lot cheaper right?
Old Dec 10, 2004 | 02:15 PM
Nope, needs to be OBD-1 as well and have all functioning emissions equipment from a Del Sol VTEC.
Old Dec 11, 2004 | 07:26 AM
Wes V's Avatar
You want a 94/95 GSR motor and will have to convert to OBD1.
Using the (carb legal) Skunk 2 intake manifold gives more room between the engine and firewall, but it's been done with the stock GSR manifold also.
It's not really hard, but EVERYTHING has to be "legal" to the engine.
Doing a B16 isn't really any easier due to the fact that you would have to set it up as a 94/94 Del Sol engine.
Wes (CARB'd b18c in 89 hatchback) Vann
Old Dec 11, 2004 | 08:18 AM
smart monkey's Avatar
you can use jdm motors but you have to make the car/engine OBD1 compliant. if you go B16a and want to make it as easy as possible use a 94-95 delsol dohc vtec swap or a jdm 2nd gen swap with the hydro trans and OBD1 parts. if you go gsr same rule applies.
Unleaded91EF
Apr 10, 2011 12:46 AM
SLOW_ASS_CRX
Aug 8, 2004 10:18 AM
gsr~hatch
Feb 12, 2004 07:35 PM
Nerologic
40
Aug 27, 2003 02:23 PM
