AC belt question?
Hello! A few weeks ago my pulley to the AC belt came off the bolt cam out causing this. I lost the bolt so im going to have to replace. I cut the belt off therefore, now I have no AC I was wondering how much it would cost to get this repaired what work is required will the enigine have to be removed? Please, give specific details thanks H-Tech.
Well here is the helms on how to replace the belt. As you can see, it is pretty easy in theory. It is going to be harder in practice because the space is going to be really cramped. But it isn't going to be that hard of a job. Since you have to replace a bolt, it will be a little bit more, but still shouldn't be that hard. You can do it yourself if you want and save yourself a lot of money. You should be able to do it in a day easily.
EDIT: server is having some issues, pics work now, but may be up and down.
Modified by PredatorGSR at 2:28 PM 12/10/2004
I'm not sure I understand.
You cut off the A/C belt. All you have to do is move a few things out of the way and put a new belt on. No engine removal required. It's very easy to do.
Sorry if I misunderstood your post.
AssPenny
Jun 3, 2002 09:57 AM
