A6 with JRSC or Z6 with JRSC
Old Dec 10, 2004 | 12:23 PM
Badass240SX's Avatar
Default A6 with JRSC or Z6 with JRSC
I'm in process of swapping my D15 for SOHC ZC (identical to d16a6). And I really want to get JRSC
My question is what would be better?
Mini-Me 10:1 CR with JRSC running 6 psi of boost
OR
SOHC ZC stock with JRSC running 6 psi of boost
Thanks
Old Dec 10, 2004 | 12:54 PM
untitled's Avatar
Default Re: A6 with JRSC or Z6 with JRSC (Badass240SX)
Mini-me. Just keep the JRSC to 6 psi or else intake temps will kill the engine.
Old Dec 10, 2004 | 01:33 PM
7PSI CRX's Avatar
If you look at the dyno chatrs on the JR website you'll see the A6 makes more HP. (for some strange reason)
I moved my JRSC from my A6 to a new Y8 and to tell you the truth, I really didn't see much of an increase.
Old Dec 10, 2004 | 01:35 PM
WhiteVX's Avatar
i had an a6 with a jrsc at 9-10 lbs of boost, that was one fun car and ran 13.5's. wish i had it back somedays.
Old Dec 10, 2004 | 01:42 PM
88civicsi's Avatar
Default Re: A6 with JRSC or Z6 with JRSC (7PSI CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7PSI CRX &raquo;</TD></TR><TR><TD CLASS="quote">If you look at the dyno chatrs on the JR website you'll see the A6 makes more HP. (for some strange reason)
I moved my JRSC from my A6 to a new Y8 and to tell you the truth, I really didn't see much of an increase.</TD></TR></TABLE>
what is the jr site?
Old Dec 10, 2004 | 01:53 PM
dr_latino999's Avatar
Default Re: A6 with JRSC or Z6 with JRSC (88civicsi)
http://www.jacksonracing.com/S...33370
Old Dec 10, 2004 | 02:19 PM
EF9_R_Killa's Avatar
dunno my sohc block codes that well but is the A6 the non vtec version? if so the hp gains would be higher well atleast smoother since its solid power from the start rather than the spike tendancies of vtec....especially when using forced induction application.
Old Dec 10, 2004 | 02:20 PM
seriously, out of the sohc motors i love the zc and 1.5L vtec. The 1.5 vtec runs strong as hell, I think a lot of people are sleeping on them....I could only imagine that thing with a supercharger on it.
GoFastMotorSports's Avatar
Default Re: A6 with JRSC or Z6 with JRSC (EF9_R_Killa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_R_Killa &raquo;</TD></TR><TR><TD CLASS="quote">
dunno my sohc block codes that well but is the A6 the non vtec version? if so the hp gains would be higher well atleast smoother since its solid power from the start rather than the spike tendancies of vtec....especially when using forced induction application.</TD></TR></TABLE>
thats why you get it tuned..........
Old Dec 10, 2004 | 03:09 PM
Default Re: A6 with JRSC or Z6 with JRSC (GoFastMotorSports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoFastMotorSports &raquo;</TD></TR><TR><TD CLASS="quote">
thats why you get it tuned..........</TD></TR></TABLE>
yah thats a given
Old Dec 10, 2004 | 07:28 PM
kess's Avatar
I have a '90 CRX D16A6 w/ JRSC and the 8lb pully upgrade. This thing honestly pulls Corvettes in the straights (Road America 2003 and 2004).
My question: can you mount this JRSC on a Y8 on a D16 block? This would result in a JRSC D16Y8. If so I'm all over it!
Old Dec 10, 2004 | 07:42 PM
91civicEX's Avatar
mini-me+jrsc will blow up unless you have good fuel management.
if you go mini me ull need to spend more money on fuel.
if you go zc ull need to spend less money.
Old Dec 10, 2004 | 10:19 PM
Thanks Everyone
I'll go with stock sohc zc with JRSC. I found out that drivablity doesn't change.
How's the gas mileage on a6 with JRSC (off boost)
Also which one do I get the D16A6 or ZC? I'm using D16A6 intake manifold and other parts, it's only ZC block and head.
Thanks again
Old Dec 10, 2004 | 11:41 PM
Jaker's Avatar
Default Re: (Badass240SX)
I regularly get 27-28 MPG city driving with boost here and there, 10 psi, DSM 450cc, Uberdata, and a basic tune on a 11:1 compression D16A6. It sees a short blast (5 miles) on the highway twice a day as well. Really short gearing with the ZC 1st to 5th and Si 4.25 final drive.
Its all in the tune.
Old Dec 11, 2004 | 08:04 AM
bump
Old Aug 21, 2005 | 05:46 PM
89dxhunchback's Avatar
Wow, 11:1 compression 10psi from a JRSC, on pump gas !!! That's not a "good tune" that's a "mack F**KING daddy tune" !! Bet its extremly fun to drive...
Old Aug 21, 2005 | 05:47 PM
Default Re: (89dxhunchback)
Opps, didn't reallize how old this was.... Sorry guys....
fat_cat
May 2, 2007 10:04 PM
andreiscv
May 17, 2004 01:59 PM
crix180
Jan 24, 2004 09:48 AM
