D16z6 head gasket????
I was wondering if any of you guys have had good or bad experiences w/ a higher compression head gasket for a d16z6? What brand of gasket did you buy and where did you get it? Maybe even comp. gains? Thanks
oem honda are just fine. you're not going to raise your compression enough for the time and effort involved in changing the gasket. look around at some pm7's or p29's (same thing) or the pm6 pistons for a better result. if you go with the dohc pistons and you find the compression is causing pre ignition or detonation you can always use a thicker head gasket until you stuff together for a good tune on the dyno. tell us more about your setup you have now and, or are going for.
USDM 4G VTEC
Sep 16, 2003 09:17 AM
SOcalistreetracer
Jun 30, 2002 03:54 PM
ryu12341
Jun 27, 2002 09:59 AM
