How to Remove Dashboard in 2000 Honda Accord coupe
Old Dec 10, 2004 | 11:08 AM
ja61999's Avatar
Default How to Remove Dashboard in 2000 Honda Accord coupe
I recently bought a 2000 Honda Accord and the Tach, idles below zero and a mechanic told me to replace the Tach and it would be fine. But, I need to know how many clips there are on the dashboard so I don't dammage it any more. It has a hole drilled cut into it for an after market Tach but no Tach.
Old Dec 10, 2004 | 11:10 AM
khenning's Avatar
Default Re: How to Remove Dashboard in 2000 Honda Accord coupe (ja61999)
You should consider buying a Haynes manual or a similar brand. Those things have all the answers for stuff like that and usually include some helpful pics. Well worth the $15 at your local autozone or where ever. Just a thought.
Old Dec 10, 2004 | 11:16 AM
notoriousB's Avatar
are you talking about the factory tach in the gauge cluster? you don't have to remove the dash to take that out.
Old Dec 10, 2004 | 11:19 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: How to Remove Dashboard in 2000 Honda Accord coupe (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">are you talking about the factory tach in the gauge cluster? you don't have to remove the dash to take that out.</TD></TR></TABLE>
Exactly, don't remove the whole dash. You just need to remove the bezel around the cluster and then the cluster from the dash. You may have to remove some other small items but nothing major. Once you have the cluster out of the dash just take it apart and replace the tach.
Old Dec 10, 2004 | 11:26 AM
philadd's Avatar
Default Re: How to Remove Dashboard in 2000 Honda Accord coupe (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly, don't remove the whole dash. You just need to remove the bezel around the cluster and then the cluster from the dash. You may have to remove some other small items but nothing major. Once you have the cluster out of the dash just take it apart and replace the tach.</TD></TR></TABLE>
remove 2 screws on top of the bezel... then just pull out. 4 screws hold in the gauge cluster. once the screws are removed, tilt the cluster forward (top towards you) to unplug the 3 electrical plugs. pull out the gauge cluster... after that the clips (and screws if you a V6) to take apart the cluster itself are pretty self-explanatory.
Old Dec 10, 2004 | 11:29 AM
ja61999's Avatar
Default Re: How to Remove Dashboard in 2000 Honda Accord coupe (philadd)
Thanks, it helped I did it already. Know any good after market tacs?
Toasted576
May 4, 2009 03:48 PM
grjp1988
Aug 19, 2008 07:33 AM
insanity tour
Mar 27, 2006 02:09 PM
Jmorin
Feb 21, 2004 06:48 PM
thevinman
Jan 19, 2003 12:39 PM
